It is currently Sun Jul 27, 2025 3:12 pm
PostPosted: Tue Aug 16, 2005 3:11 am
I am going to try this again. This is a little jig I made to drill holes for Grover open back tuners.
PostPosted: Tue Aug 16, 2005 3:17 am
Here's the explanation from the other thread that didn't work.
Iwas reading a thread on the "other" forum about how to step drill tuner holes for Grover Sta-Tite open back tuners. Having access to a metal lathe at work, I came up with this little jig that works very well. It is basically a piece of 1 1/4" steel rod with a 1/4" hole drilled in the center. I milled a little "nubby" on one end to press fit into an 11/32" hole in the headstock.
Drilled the tuner holes with the 11/32 bit to the proper depth for the bushings.
Stuck the little round thingy in one of the holes and used it for a drill guide for the 1/4" drill bit.
Result: Perfectly centered holes.
PostPosted: Tue Aug 16, 2005 3:30 am
I use this. I know it says in the catalog that it is for the Waverly tuners but it works just fine for the Grover tuners as well.
PostPosted: Tue Aug 16, 2005 3:39 am
John, that's what made me think of doing this. This one was a heck of a lot cheaper . It took about 5 minutes to make and was free. Just an old cheapskate at heart.
PostPosted: Tue Aug 16, 2005 3:41 am
yeah, cheep of you have the right tools.
PostPosted: Tue Aug 16, 2005 7:18 am
[QUOTE=John How] yeah, cheep of you have the right tools. [/QUOTE]
Good point. I don't see why it couldn't be made out of some kind of hardwood though.
PostPosted: Tue Aug 16, 2005 3:16 pm
First name: Coe
Last Name: Franklin
City: Decatur
Rock hard maple lasts for awhile on this type of things, but the center gets "wallered out" after so long.
